Hello Guest it is November 13, 2026, 08:05:13 PM
Author Topic: Safe z question  (Read 13080 times)
Safe z question
« on: March 15, 2016, 07:03:03 AM »
I had my machine set up with a 1.5" safe z. When I hit the stop button on the mach3 screen it would raise the z to 1.5". Now I set up homing switches and when I hit stop it raises the z axis all the way to the top(homed position). Is there a way I can get it to only raise a small amount like it used to?  Also I am using the 2010 screenset.
Sent from my iPhone using Tapatalk
Re: Safe z question
« Reply #1 on: March 15, 2016, 07:15:50 AM »
Your safest option is to setup safe z to use machine coordinates, and use a negative number like Z-2. That way you will always have the same SafeZ position.
Check your Config >Safe Z settings, and see what it's set to?
Re: Safe z question
« Reply #2 on: March 15, 2016, 07:21:23 AM »
You have a few options for Safe Z, Machine Coords which I prefer as I always know exactly where it will go which I have set to -5 which means it will raise to 5mm before fully up.
There is also Incremental which will raise it up the value you entered from the position you are presently at.
You also have a Work Coords option, so say you have entered 5 for it then it will move to 5 in the work coordinate system.
Re: Safe z question
« Reply #3 on: March 15, 2016, 07:22:18 AM »
Man I must be getting really slow at typing now , Ger replied 5mins before I did LOL
Safe z question
« Reply #4 on: March 15, 2016, 12:22:55 PM »
You guys are great. I will try it tomorrow night.
Re: Safe z question
« Reply #5 on: March 20, 2016, 05:13:33 AM »
It worked.  I had the safe_z setup wrong.  Changed it to -4 machine coordinates and it works great.  Thank you guys for your help.
