Hello Guest it is October 24, 2026, 09:48:31 AM
Author Topic: Open Mach4 with default toolpath  (Read 20763 times)
Offline dah79
  •  35 35
Re: Open Mach4 with default toolpath
« Reply #10 on: March 29, 2016, 04:54:13 PM »
You are correct, I am running XP.
Thanks!
Offline DazTheGas
  •  778 778
  • DazTheGas
« Reply #11 on: March 29, 2016, 04:59:26 PM »
Debugging code is fun, finding a friend who has xp is a challenge ;-)
DazTheGas
Offline dah79
  •  35 35
« Reply #12 on: March 29, 2016, 06:03:57 PM »
Ok,  I figured out it has something to do with the screen set I am using.  I have attached the screen set that I am trying to use AND the one that I added the 2 lines to.  I tried deleting the 2 lines that I added and the screen still would not load.  If I used a different screen set (wx6.set), everything loaded fine, as well as my default toolpath.
I know, I should have made a copy of the screen set before changing it, but....I didn't.  As stated, I am just getting started and am not connected to any machine, just playing in SIM mode.  I am trying to also get a PoKeyes module installed, but I deleted the plug ins until I get this figured out.
As far as I know, I did not change anything other than the 2 lines shown in an earlier post and the file 'compiles' without any errors.
Thanks for any help.
Offline DazTheGas
  •  778 778
  • DazTheGas
« Reply #13 on: March 29, 2016, 06:17:20 PM »
The tab coords had been moved in the screen editor.
DazTheGas
Offline dah79
  •  35 35
« Reply #14 on: March 29, 2016, 06:46:43 PM »
Thanks, but how do I fix it?
Offline dah79
  •  35 35
« Reply #15 on: March 30, 2016, 08:33:16 AM »
Figured it out.  Have no idea how everything got shifted.  Thanks for the help.
