Hello Guest it is November 13, 2026, 08:05:17 PM
Author Topic: X-axis is dead  (Read 9528 times)
X-axis is dead
« on: March 14, 2016, 10:33:52 AM »
I'm using an XP-SP2 & 32-bit computer with the ECP parallel port set to 378h.  I'm driving a 3-axis TB 6560 board.  When i use Mach3's on-screen pendant to jog Y & Z tjhey work fine but x doesn't move.  The on-screen DRO reflects movement  of each axis.  The ports & pins are configured as directed.
Using the same input pin assignment I can control each channel reliably with an Arduino---- without using Grbl.
I have a 2nd TB6560 board that reacts the same way to Mach3 but the z-axis won't reverse ------- which isn't a Mach3 issue.
It would seem that pins 1 & 7 are not the correct x-axis pins.   (THEY WORK WITH THE ARDUINO).
Did II overlook something?
Does anyone have any suggestions???
Thanks in advance.
Re: X-axis is dead
« Reply #1 on: March 14, 2016, 02:28:58 PM »
If the PC & PP work with something else the obvious conclusion is something amiss with the TB 6560 board.
Having travelled this route I strongly suggest a decent BOB with separate decent drivers for each axis, factoring in your time and frustration the TB multi-axis integrated boards don't save you much and when one axis driver dies the whole thing is scrap,
 - Nick
Re: X-axis is dead
« Reply #2 on: March 16, 2016, 08:54:09 AM »
And I MAY have a defective cable.
(What is a BOB??)
Offline Davek0974
  •  2,606 2,606
Re: X-axis is dead
« Reply #3 on: March 16, 2016, 09:24:51 AM »
BOB or bob or Bob, is a Break Out Board - the bit between your pc and the motor drives etc
