Hello Guest it is October 21, 2026, 07:01:50 AM
Author Topic: Z axis acting up  (Read 11250 times)
Z axis acting up
« on: March 12, 2016, 09:09:48 PM »
My first full day with the Gecko540 and Mach3...things were great until I loaded a file with a tool change...the Z touch macro works fine UNTIL the second tool change (not the first one at the beginning of the file)...after the second plate touch off on the Z, the Z axis moves up (away from the work) and cuts air...at this point I stop the cut and try and re touch off the Z, it runs up and crashes at the top...does it every time, it is repeatable, I cannot figure out what is wrong...I made a small file with a single line, then tool change, another single line, it screws up all of the time on the second tool change (and Z touch off)...I jacked with it for several hours, cannot find anything wrong...
I have attached my xml, the macro for touch off, and a simple file that screws up on the second tool change...
I hope someone can help!
Re: Z axis acting up
« Reply #1 on: March 13, 2016, 08:40:09 AM »
Another "self inflicted wound"! I could write a manual on such things!!!
I thought this morning I would type in the Gcode line by line and try and figure out WTF (why!) the Z axis was too high wrong direction and cutting air) after a tool change...hmmmm...what's this?!? G43H4?!? What does this do? I am not familiar with G43? Tool length compensation?!? I have not matched my vcarve tool table with Mach3 yet, BUT, the tool it was choosing had a 1" length, the one I was coming from had a .25" length?!? Could it be this simple?!? YES IT CAN! Could not find in the configs where to turn compensation off, but I set all tool lengths to zero and VIOLA!! Everything is peachy again!
Hope this helps soemone!
« Reply #2 on: March 13, 2016, 09:40:09 AM »
If you're using V-Carve Pro, and have no plans to use G43, then you should edit your post processor and remove the G43 commands.
« Reply #3 on: March 13, 2016, 09:46:07 AM »
Thanks for the input...while you are "on the phone", I searched the DRO and wiki...Is there a way to show the tool description? I see all of the DRO's for tool number, diameter, etc, unless I overlooked it, I cannot find a way to show the description...
Thanks as always!
« Reply #4 on: March 13, 2016, 10:35:19 AM »
Use GetToolDesc() and write it to a label.
« Reply #5 on: March 13, 2016, 10:39:17 AM »
Thanks! I guess that was in the Vbasic wiki! Forgot to look in there!
