Hello Guest it is October 20, 2026, 04:48:16 PM
Author Topic: Tool Path Not Displaying Properly  (Read 25767 times)
Re: Tool Path Not Displaying Properly
« Reply #10 on: March 11, 2016, 02:46:59 PM »
Certainly looks like the wrong IJ mode to me.
« Reply #11 on: March 11, 2016, 02:51:21 PM »
I changed it but still got the same error.
Am I changing it in the correct spot (see pic).
« Reply #12 on: March 11, 2016, 03:42:01 PM »
I put the 2 side by side and loaded the same g-code.
The only difference that I can see between the 2 computers is the status.
One shows "profile 2"
The other shows "pocket 3"
Not sure what this means or if it is the issue.
« Reply #13 on: March 11, 2016, 06:26:00 PM »
My other computer has Vista, this one has window 7.............so is that the issue?  Any way to continue using 7?
« Reply #14 on: March 12, 2016, 12:02:36 AM »
Unfortunately, still at a loss here.  Can not figure it out.  I uninstalled everything and re-installed everything following each step to the finest detail.  Any help would be appreciated.  Thanks!
« Reply #15 on: March 12, 2016, 01:56:28 AM »
I tried to open it in Openscam also and get the same thing.  So I'm thinking it is a software/hardware issue.  Any thoughts?
« Reply #16 on: March 13, 2016, 12:30:27 AM »
Figured out the issue.  I was in Demo mode the whole time (as indicated by Gerry earlier)....stupid me!.  Sorry for wasting everyone's time on my oversight.  I was only limited to 500 lines of code, therefore, only seeing a very small portion in my display.  Thanks for the help!
