Hello Guest it is October 24, 2026, 12:58:50 AM
Author Topic: Pokeys pin setup  (Read 6939 times)
Pokeys pin setup
« on: March 11, 2016, 01:32:18 AM »
Does anyone have any info on pokeys pins.
By default pokeys plugin for M4 set home status to pokeys pulse engine home status.
The same for limits.
Which are the correct physical pin on the pokeys for home and limit status?
Tom
Re: Pokeys pin setup
« Reply #1 on: March 11, 2016, 07:08:51 AM »
The physical pins on pokeys are programmed in the unit for their given function.  Some pins are fixed for only input/outputs, etc.   You can download the view of your device and run the pokey windows application which will show you how the device is currently programmed.
Russ
