Hello Guest it is October 20, 2026, 03:48:00 PM
Author Topic: Lazyturn Problems  (Read 10457 times)
Lazyturn Problems
« on: March 09, 2016, 07:11:56 AM »
Hi all
I am using Lazyturn for my SEIG C6 CNC lathe
Everything is working fine, and i can get the machine to run accurately, however when the machine goes to run the finishing path is cuts to far into the profile.
It is as if it is getting Radius and Diameter mode mixed. I have tried different combinations of radius and diameter mode but the same problem exist
also when I run in Radius mode, the rough and fine paths match up but the first pass takes a huge chuck out of the material. ( at the minute im using dowel to test, if id run metal it would have been a disaster )
Any help would be greatly appreciated, as im fresh out of ideas.
PS
In the machine control software G8 and G7 are not supported commands
HELP!!!!!!
Re: Lazyturn Problems
« Reply #1 on: March 10, 2016, 05:52:20 AM »
Post the DXF and Gcode file and I will have a look.
NOTE: Always be consistent in how the drawing, LT mode and Mach Lathe mode is done , never mix them.
You can test the tool  location to the profile and also simulate the cutting for a pass. You would see if the tool is cutting to deep into the stock or gouging.
« Reply #2 on: March 10, 2016, 06:16:29 AM »
Hi Rich
Many thanks, This should be a simple thing but it has my head in a spin ( excuse the pun !!! ) I made a slight error in my original posy it is a sieg kc6s lathe
Here is the GCODE from Lazyturn
( LazyTurn Alpha 1.1 )
(Thursday, March 10, 2016 )
none set
 (--------------ToolPath 1 of 2 )
(Change to Tool: UnNamed   -R0.0100-IC6.0000 )
T0000
S3000 F500.00 M3
G0Z0.1100
G0X18.1700
G1 F1000.0000  X17.9500
 X17.5500
 F500.0000  Z-23.7466
G0  X17.7500
 Z0.1100
G1 F1000.0000  X17.5500
 X17.3500
 F500.0000  Z-23.7466
G0  X17.5500
 Z0.1100
G1 F1000.0000  X17.3500
 X17.1500
 F500.0000  Z-23.7466
G0  X17.3500
 Z0.1100
G1 F1000.0000  X17.1500
 X16.9500
 F500.0000  Z-23.7466
G0  X17.1500
 Z0.1100
G1 F1000.0000  X16.9500
 X16.7500
 F500.0000  Z-23.7466
G0  X16.9500
 Z0.1100
G1 F1000.0000  X16.7500
 X16.5500
 F500.0000  Z-23.7466
G0  X16.7500
 Z0.1100
G1 F1000.0000  X16.5500
 X16.3500
 F500.0000  Z-23.7466
G0  X16.5500
 Z0.1100
G1 F1000.0000  X16.3500
 X16.1500
 F500.0000  Z-23.7466
G0  X16.3500
 Z0.1100
G1 F1000.0000  X16.1500
 X15.9500
 F500.0000  Z-23.7466
G0  X16.1500
 Z0.1100
G1 F1000.0000  X15.9500
 X15.7500
 F500.0000  Z-23.7466
G0  X15.9500
 Z0.1100
G1 F1000.0000  X15.7500
 X15.5500
 F500.0000  Z-23.7466
G0  X15.7500
 Z0.1100
G1 F1000.0000  X15.5500
 X15.3500
 F500.0000  Z-23.7466
G0  X15.5500
 Z0.1100
G1 F1000.0000  X15.3500
 X15.1500
 F500.0000  Z-23.7466
G0  X15.3500
 Z0.1100
G1 F1000.0000  X15.1500
 X14.9500
 F500.0000  Z-23.7466
G0  X15.1500
 Z0.1100
G1 F1000.0000  X14.9500
 X14.7500
 F500.0000  Z-23.7466
G0  X14.9500
 Z0.1100
G1 F1000.0000  X14.7500
 X14.5500
 F500.0000  Z-23.7466
G0  X14.7500
 Z0.1100
G1 F1000.0000  X14.5500
 X14.3500
 F500.0000  Z-23.7466
G0  X14.5500
 Z0.1100
G1 F1000.0000  X14.3500
 X14.1500
 F500.0000  Z-23.4626
G0  X14.3500
 Z0.1100
G1 F1000.0000  X14.1500
 X13.9500
 F500.0000  Z-22.6711
G0  X14.1500
 Z0.1100
G1 F1000.0000  X13.9500
 X13.7500
 F500.0000  Z-21.8795
G0  X13.9500
 Z0.1100
G1 F1000.0000  X13.7500
 X13.5500
 F500.0000  Z-21.0880
G0  X13.7500
 Z0.1100
G1 F1000.0000  X13.5500
 X13.3500
 F500.0000  Z-20.2964
G0  X13.5500
 Z0.1100
G1 F1000.0000  X13.3500
 X13.1500
 F500.0000  Z-19.5049
G0  X13.3500
 Z0.1100
G1 F1000.0000  X13.1500
 X12.9500
 F500.0000  Z-18.7133
G0  X13.1500
 Z0.1100
G1 F1000.0000  X12.9500
 X12.7500
 F500.0000  Z-17.9218
G0  X12.9500
 Z0.1100
G1 F1000.0000  X12.7500
 X12.5500
 F500.0000  Z-17.1302
G0  X12.7500
 Z0.1100
G1 F1000.0000  X12.5500
 X12.3500
 F500.0000  Z-16.3387
G0  X12.5500
 Z0.1100
G1 F1000.0000  X12.3500
 X12.1500
 F500.0000  Z-15.5471
G0  X12.3500
 Z0.1100
G1 F1000.0000  X12.1500
 X11.9500
 F500.0000  Z-14.7555
G0  X12.1500
 Z0.1100
G1 F1000.0000  X11.9500
 X11.7500
 F500.0000  Z-13.9640
G0  X11.9500
 Z0.1100
G1 F1000.0000  X11.7500
 X11.5500
 F500.0000  Z-13.1724
G0  X11.7500
 Z0.1100
G1 F1000.0000  X11.5500
 X11.3500
 F500.0000  Z-12.3809
G0  X11.5500
 Z0.1100
G1 F1000.0000  X11.3500
 X11.1500
 F500.0000  Z-11.5893
G0  X11.3500
 Z0.1100
G1 F1000.0000  X11.1500
 X10.9500
 F500.0000  Z-10.7978
G0  X11.1500
 Z0.1100
G1 F1000.0000  X10.9500
 X10.7500
 F500.0000  Z-10.0062
G0  X10.9500
 Z0.1100
G1 F1000.0000  X10.7500
 X10.5500
 F500.0000  Z-9.2147
G0  X10.7500
 Z0.1100
G1 F1000.0000  X10.5500
 X10.3500
 F500.0000  Z-8.4231
G0  X10.5500
 Z0.1100
G1 F1000.0000  X10.3500
 X10.1500
 F500.0000  Z-7.6316
G0  X10.3500
 Z0.1100
G1 F1000.0000  X10.1500
 X9.9500
 F500.0000  Z-6.8400
G0  X10.1500
 Z0.1100
G1 F1000.0000  X9.9500
 X9.7500
 F500.0000  Z-6.0485
G0  X9.9500
 Z0.1100
G1 F1000.0000  X9.7500
 X9.5500
 F500.0000  Z-5.2569
G0  X9.7500
 Z0.1100
G1 F1000.0000  X9.5500
 X9.3500
 F500.0000  Z-4.4654
G0  X9.5500
 Z0.1100
G1 F1000.0000  X9.3500
 X9.1500
 F500.0000  Z-3.6738
G0  X9.3500
 Z0.1100
G1 F1000.0000  X9.1500
 X8.9500
 F500.0000  Z-2.8822
G0  X9.1500
 Z0.1100
G1 F1000.0000  X8.9500
 X8.7500
 F500.0000  Z-2.0907
G0  X8.9500
 Z0.1100
G1 F1000.0000  X8.7500
 X8.5500
 F500.0000  Z-1.2991
G0  X8.7500
 Z0.1100
G1 F1000.0000  X8.5500
 X8.3500
 F500.0000  Z-0.5076
G0  X8.5500
 Z0.1100
G0X18.1700
G0Z0.1100
 (--------------ToolPath 2 of 2 )
 (-------------- Fine Path -----------------)
T0000
S3000 F500.00 M3
G0 X8.9750
G0 Z0.1100
G1 Z0.1100 X4.1066
  Z-0.2660 X4.2453
  Z-23.6357 X7.1977
  Z-23.7466 X7.1035
G0 X7.2977
   Z0.1100
G1 Z0.1100 X4.0000
  Z-0.2898 X4.1475
  Z-23.6045 X7.0929
  Z-23.7466 X6.9723
  Z-23.7466 X6.9723
G0 X8.9750
(--------------End of Finish path-----------)
 M5M30
(-------  End of File -------)
 Sorry i cant seem to post the dxf. however it is a very simple taper. Tapering from 8 - 14 over  23.75 mm length
Many thanks  for your help Rich , can you suggest another type of free program that would perform this operation ??
Here is the dxf, drawn in Solidworks
« Reply #3 on: March 10, 2016, 07:46:07 AM »
Ahhhh, free, simple lathe cam that works; the holy grail.  I couldn't find one either.
If it's a simple taper, will the wizard that comes with Mach3 Turn work?  I've used it and it works well.
Milton from Tennessee ya'll.
« Reply #4 on: March 11, 2016, 06:31:51 AM »
Attached is a version 12 DXF backplot of the code you posted.
- RED are the pullouts / rapids
- BLUE are the machining at feedrate
- MAGENTA is a 8x14 x 23.75 long taper starting at 0,0,0
Looks like the rough is in diameter and the finish is radius mode??
I really need a Version 12 DXF of YOUR drawing of the taper.
There should be no problem doing this in Lazyturn and you could always use one of the wizards as they also work.
Note that you should see the pathing in simulation and see that thepathing is not correct. There is a manual for LazyTurn.
