Hello Guest it is October 20, 2026, 03:07:34 PM
Author Topic: Questions abount CNC  (Read 10566 times)
colbertsignworks
« on: May 15, 2007, 05:23:10 PM »
I own a Sign Shop and I have had a request for some plastic name plates. A little smaller than the ones you would find on an office door. They would be routed with
text. The order calls for 100 plates with 100 names. My question is, using the Mach software, how hard is it to set up a CNC Machine to do 100 different names?
Is the process difficult and time consuming or can the changes be made quick and simple.
I have never used and am not familiar with CNC machines but considering purchasing one for this job if it is not a difficult task.
Thanks for any help in this matter.
Re: Questions abount CNC
« Reply #1 on: May 15, 2007, 09:53:43 PM »
You would love CNC. I have sent you a personal message.
« Reply #2 on: May 16, 2007, 01:25:44 AM »
There is a learning curve as with all things, how steep will depend on many factors. The bigest one will be whether the machine is set up with Mach or whether you have to convert it over. I suggest you look at the videos and manuals and also download a copy of Mach and start messing with it, all can be had by using the Download menu at the top of the forum.
 As for the text, there is a write wizard in Mach, although I have never actually used it it should do what you want. Simply type the text in the box, put in a few dimensions and it will write the code for you.
Offline GPDC
  •  43 43
« Reply #3 on: May 16, 2007, 11:34:23 AM »
just a thought.....with so many guys hanging around here that are already where you need to be RIGHT NOW, can you just sub this order out to a responsible party and in doing so, you buy yourself some time to get a system s/u for yourself...? and NO, I'm not applying for a job, but I'll bet somebody in here could help you....gpdc
