Hello Guest it is October 21, 2026, 09:13:43 AM
Author Topic: Can’t get Probe to Work  (Read 92576 times)
Re: Can’t get Probe to Work
« Reply #70 on: March 03, 2016, 08:25:56 PM »
So it was working correctly earlier, and then you decided to make changes, and now it's not working again?
Offline kolias
  •  1,165 1,165
« Reply #71 on: March 03, 2016, 10:04:24 PM »
It never worked good Gerry, I dont know what you mean
Nicolas
Offline bfgstew
  •  91 91
  • DOH!!!!!!!
« Reply #72 on: March 03, 2016, 11:16:46 PM »
Post 65 you say it worked, now you have gone back to original set up and it doesnt work.
Re read the post and work it out because i have a funny feeling you are on your own.!!!!!!!!!
Offline kolias
  •  1,165 1,165
« Reply #73 on: March 04, 2016, 08:05:49 AM »
Thank you bfgstew for pointing out to me
Re wiring all as per post #14 now the probe works. Using my script the bit went down to touch the plate and up 1” as it should. The LED light in the diagnostic screen is OFF and the volts between the plate and chuck is 5.1 with correct polarity (black wire to clip and red to plate)
However I must point out that this wiring is not a universal fix for the C10 BOB. To my limited knowledge in electronics it depends I think on your router spindle insulation. I have used the C10 before with other routers like the same as I have now (Bosch Colt), air cooled spindle and a Taig spindle and never had any problem neither did use any resistor. When I used the air cooled spindle I also had the C41 variable speed control board.
Thank you all for the help
Nicolas
