Hello Guest it is August 06, 2026, 04:19:22 PM
Author Topic: 90 degree sharp turns  (Read 23088 times)
« on: February 22, 2016, 11:55:15 AM »
Hello,
Hope someone can advice me please.
I'm new to this, got my machine setup and calibrated.
I'm trying to do a square but my corners are being cut slightly rounded. I would like them to be 90degree turns.
If there anyway to do this properly?
I'm using DevFoam pro and Mach 3.
Thank you
Re: 90 degree sharp turns
« Reply #1 on: February 22, 2016, 01:22:36 PM »
To get a sharp corner you need to change from G64 mode to G61 mode until you get around teh corner then switch back.  OR change the settings in CV mode to exclude any angle less then 89 degs
« Reply #2 on: February 22, 2016, 01:31:39 PM »
Hello, thank you for that. Will give it a try:)
Many thanks
« Reply #3 on: February 22, 2016, 01:33:45 PM »
In General Config, check "Stop CV on Angles<" and set it to 89. You can then get sharp corners with CV mode on.
« Reply #4 on: February 23, 2016, 08:45:33 AM »
Yes! Pretty good corners. Thank you for your kind comments.
Jason
