Hello Guest it is October 16, 2026, 07:04:56 AM
Author Topic: SheetCam And ToolChange ?  (Read 9734 times)
Offline Davek0974
  •  2,606 2,606
« on: February 20, 2016, 11:46:50 AM »
Hi all,
I'm building a small CNC mill and trying to figure out how to program sheetcam to tell Mach3 I want to change from a roughing tool to a finish tool?
I have a toolpath set in SC and it all looks good, I've left a finishing allowance etc.
I presume I need to program a code snippet to tell Mach3 I want to do a manual tool change as the tool holder is a collet and all tools will be referenced to zero every change so i'm not using the tool table etc. - all entries are zero in the TT
Then I presume I need to create another operation in SC to run the finish pass on the new tool???
Of course I may be totally wrong here :)
If right, what code tells Mach to stop and wait for run start?
Offline Davek0974
  •  2,606 2,606
Re: SheetCam And ToolChange ?
« Reply #1 on: February 20, 2016, 11:57:48 AM »
Ignore this question, I've just re-read my code and sheet cam takes care of it by moving to a programmed position and calling M6 T1, 2 etc so as long as my tool table is empty it should be ok.
« Reply #2 on: February 20, 2016, 02:18:10 PM »
Dave , You are getting easier and easier to help these days.
Offline Davek0974
  •  2,606 2,606
« Reply #3 on: February 20, 2016, 02:31:33 PM »
Self-help forum :)
I scanned the code and missed the tool change bit first time round thats why it didn't make sense, found it with a search :)
Test running it in my laptop setup of Mach3 gives exactly the desired effect :)
