Hello Guest it is November 22, 2026, 07:35:02 AM
Author Topic: Movement after tool change  (Read 8771 times)
« on: February 13, 2016, 11:26:06 AM »
In my workflow (simulated of course! Still using TinyG), when I get a tool change, sometimes I jog the XY a little to do the touch off with the new tool. After I cycle start again, it moves back to where it was before the tool change, then back to the next position...is there a way I can write some code to eliminate it going back to where it was, and after cycle start, go to the next position?
Seems like I should be able to grab the XY for the next line?!? Dont know how buffering and other things might effect this...maybe something simple?!? Don't know!
Leslie
Re: Movement after tool change
« Reply #1 on: February 13, 2016, 11:31:01 AM »
The only reason it returns to the point it does after a tool change is because you told it to (;-)
« Reply #2 on: February 13, 2016, 01:19:44 PM »
Guess I should have looked at M6End!   ::)
Thanks!
