Hello Guest it is November 25, 2026, 12:09:43 AM
Author Topic: Need Help -- Motors not responding.  (Read 9642 times)
« on: February 12, 2016, 07:57:47 AM »
I need help.
I can’t get my motors moving — they are locked.
I suspect that mach3 is not talking to my board at all.
I recently purchased this setup.
http://www.automationtechnologiesinc.com/products-page/nema34-closed-loop-stepper-motor-system-hybrid-servo-kit/nema34-1128-oz-in-closed-loop-stepper-motors-4-axis-cnc-kit-110vac220vac
I’ve created my own enclosure, I hooked it up to a C11 Board
http://cnc4pc.com/Tech_Docs/C11-R9_9_USER_MANUAL.pdf
The wiring diagram I followed is here:
http://www.automationtechnologiesinc.com/wp-content/plugins/download-monitor/download.php?id=328
I triple checked all the connections and they seem good.  The LEDS on the Hybrid Servo motors are lighting green.  They are looked and I can’t move them powered.
The c11 board seems to be lighting up as expected the individual LEDS to the pins are lighting up as I would expect them to, power LEDS are lighting up as is “output” LED.
My ESTOP signal switch works from the SWITCH to the BOARD — but doesn’t seem to be sending a signal from the BOARD to Mach 3.
I am running Windows XP, SP3.
I installed a PCI Serial Port.
The Serial Port is being recognized my Windows XP as LPT 1 and is using
I/O Range: AC00-AC07
I/O Range A800-A807
I installed Mach 3 (it’s currently in demo mode).
I setup up Port 1 in Mach 3 = 0xac0
X AXIS on Port 1 Step Pin # 8 (Step High Active) and Direction Pin # 9 (Dir High Active)
Y AXIS on Port 1 Step Pin # 6 (Step High Active) and Direction Pin # 7 (Dir High Active)
Z AXIS on Port 1 Step Pin # 4 (Step High Active) and Direction Pin # 5 (Dir High Active)
A AXIS on Port 1 Step Pin # 2 (Step High Active) and Direction Pin # 3 (Dir High Active)
ESTOP on Port 1 - Pin 15 (active high)
Output 1 on Port 1 - Pin 1 (active high)
Output 2 on Port 1 - Pin 16 (active high)
Any help would be appreciated including paid phone help.
David Hunt
david@huntsolutions.com
267-221-4500
Re: Need Help -- Motors not responding.
« Reply #1 on: February 12, 2016, 09:34:56 AM »
Do the DIR. LED's change as you jog in opposite directions ?
Typically active low, button NC to indicate any open on the circuit.
Might double check the config. and verify.
This might help:  http://www.machsupport.com/forum/index.php/topic,14910.0.html
And, you might consider rerouting the pc cable away from the toroid.
« Last Edit: February 12, 2016, 09:36:43 AM by Overloaded »
« Reply #2 on: February 12, 2016, 10:21:32 AM »
@Overloaded,
THat helped a GREAT deal.
This might help:  http://www.machsupport.com/forum/index.php/topic,14910.0.html  ( I changed my port to 0ac00 from 0xac0 ) and I got all my motors spinning!  Thanks so much
« Reply #3 on: February 12, 2016, 10:59:07 AM »
Very happy for Ya.
That is a nice looking kit ... and a fine job you have done with the enclosure!
Kind regards,
Russ
