Hello Guest it is October 21, 2026, 07:02:43 AM
Author Topic: STEPS PER help - losing my mind  (Read 11068 times)
« on: February 11, 2016, 12:31:02 PM »
Hey everyone.
I need some help with the STEPS PER part of Mach 3. Putting a dial indicator on my CNC movement doesn't really equate to my STEPS PER calculations.
Also, upon cutting 1" squares. My squares seem to turn out 1.0000" Y, and 1.0040" X
Are STEPS PER subject to fine tuning or is the calculations you do, depict exactly what the STEPS PER should be?
Here is the info on my machine:
Techno Isel Model 040 http://www.techno-isel.com/Tic/H830/HTML/H830P046.htm
Leadshine Closed Loop stepper motors and drives http://www.ebay.ca/itm/Leadshine-Closed-Loop-stepper-Drive-motor-HBS507-573HBM20-1000-3PH-2NM-57mm-NEW-/121559936057?hash=item1c4d896c39:g:dxoAAOSwVL1V-OrR
Here is the info I am putting into a Stepper calculator revision 1:
Degree/step - 1.2
Pulse/rev (micro stepping) - 4000
Leadscrew threads/in - 5.08
Thread starts - 1
Steps Per Inch - 20,320
When setting up a dial indicator to the CNC movement of X and Y, 20320 step per doesn't get me to 1". 20335 gets me to 1" right on the money.
Does anyone have any ideas or can point out what I am doing wrong?
Re: STEPS PER help - losing my mind
« Reply #1 on: February 11, 2016, 12:42:20 PM »
Have you performed a comprehensive backlash inspection on the axis' ?
Are you approaching the indicator at least 2 moves in the SAME direction ?
« Reply #2 on: February 11, 2016, 12:47:23 PM »
I have made sure to minimize the backlash as much as possible.
For instance, the axis starts at -1.0". I run the axis to +0.0", which is against the dial indicator (then I zero my dial indicator). Then I command +1.0" in Mach 3 and see if the axis moved that amount. Which is does, but at a different steps per inch amount than calculated.
« Reply #3 on: February 11, 2016, 01:17:12 PM »
With a perfect machine in a perfect world, yes, calculations.
If what you are measuring is consistent in all areas of movement, I would adjust the steps-per accordingly.
I'd still be suspicious of a mechanical issue though.
« Last Edit: February 11, 2016, 01:19:56 PM by Overloaded »
« Reply #4 on: February 11, 2016, 04:06:04 PM »
I agree Overloaded. Nothing is perfect and calculations are good enough to get you close. Then adjust counts per based on actual measurements. If 20335 gets you to one inch then so be it.
« Reply #5 on: February 11, 2016, 04:51:34 PM »
Another option would be to use the axis calibration feature in Mach , "ALT 6" tab to get the screen.
Works very nicely. For the move, the longer the better, ie; if you have 6" of axis movement do a 5" move.
