Hello Guest it is October 20, 2026, 02:57:56 PM
Author Topic: Hot wire 4 axis Foam cutter  (Read 10118 times)
« on: February 10, 2016, 06:17:22 PM »
Hello I'm Igor. New user with Mach 3. Just started and registered. And have many questions. Primarily would like to use program with Profili , and Dev Wwing foam . Will do some hobby foam cutting for models of airplane. I wish some one help me to guide primarily familiar to use Mach 3 with 4 axis,hot wire foam cutter. How can I set up program for manually to move each Axis and both together , just for sheet of foam to cut out of block of foam ? Would appreciate to guide me up. Thank you !.
  •  9,374 9,374
Re: Hot wire 4 axis Foam cutter
« Reply #1 on: February 11, 2016, 12:33:40 AM »
Hi Igor,
Welcome to the forum.
If you use the Search option (top of main page) there are a number of threads, some of which may be of interest to you.
This is just one of them  http://www.machsupport.com/forum/index.php/topic,31624.0.html
If you have any specific problems with setting-up your machine just ask away and there are many here who will be only too pleased to provide help.
