Hello Guest it is October 21, 2026, 08:04:41 AM
Author Topic: Mini-Mills - any good???  (Read 51462 times)
Re: Mini-Mills - any good???
« Reply #20 on: February 08, 2016, 04:14:53 AM »
Hmmm.......
Make it a little bigger with a built in drip pan allowing for removable spoil board / metal bed.
May as well add ability for a future plasma capability!
Offline Davek0974
  •  2,606 2,606
« Reply #21 on: February 08, 2016, 04:23:19 AM »
LOL, having seen what it does now, I would never want to mix plasma with any sort of other machine :) Two totally different beasts here - plasma needs massive acceleration and speeds unto around 9000mm/min (45A system) and machining needs more rigidity at the expense of speed and acceleration.
Cutting figures -
3mm single flute tool,
5000 series aluminium,
1mm depth of cut,
Pocket milling ( a hard task),
10,000 rpm,
323mm/min cut speed - way lower than plasma
Cutting force - 8Nm - plasma would be zero (unless you like torch diving :) )
So there is no comparison really apart from both being CNC.
Drip pan is a good idea to allow for some sort of coolant, spoil board can be simply mounted on whatever rigid bed is used.
« Reply #22 on: February 08, 2016, 06:52:40 AM »
Bridgeport would be a better route if intending to do metals only but if wanting to do wood then I would think a gantry style router would be the best option. It would also be able to do non-ferrous metals if built rigid enough  but wouldn't be much use at steels/stainless etc.
Regarding the feeds and speeds you quoted, seems slow to me, I never use single flute cutters but even using one I would be expecting double that feedrate at least and much bigger DOC as well, then again it all boils down to the rigidity of the machine I suppose.
« Reply #23 on: February 08, 2016, 07:33:14 AM »
dont dismiss the cheap stuff.  Flimsy but a great way to learn cnc and a platform to build/rebuild from.
Offline stirling
  •  2,188 2,188
  • UK
    • www.razordance.co.uk
« Reply #24 on: February 08, 2016, 08:00:05 AM »
direct answer to your thread title/question - I wouldn't really regard any of those you list as mills. They're all routers really whatever their quality or lack of.
I saw a comment once on the uk site which I think sums things up quite well. It went something like: "Any router will eventually scratch its way through ally - that's not to be confused with milling though".
« Reply #25 on: February 08, 2016, 08:10:32 AM »
^  Ok, so I totally LOVE THAT QUOTE!
Offline Davek0974
  •  2,606 2,606
« Reply #26 on: February 08, 2016, 08:18:55 AM »
BP would get in a tizzy trying to get up to wood speeds i think :) Also dries all the oil out of the ways :(
The cut speeds i quoted, in my ignorance, taken direct from an online CNC speed/feed calculator so I won't say correct or not.
Offline Davek0974
  •  2,606 2,606
« Reply #27 on: February 08, 2016, 08:53:26 AM »
I nearly bought one so I'm not dismissing them as such but after spending a whole day Sunday reading stuff on them, I think I can make a far better unit myself.
That last picture looks to be Alu maybe 5mm thick??
What sort of settings were you running there??
Offline Davek0974
  •  2,606 2,606
« Reply #28 on: February 08, 2016, 08:54:08 AM »
Yeah fair enough, mill is an exaggeration, multi-purpose machine maybe?
« Reply #29 on: February 08, 2016, 09:19:12 AM »
Like i mentioned earlier if you want a great do everything machine build a fixed gantry mill . It can do everything to a point.
