Hello Guest it is November 13, 2026, 11:19:24 PM
Author Topic: Macro for inputs and outputs  (Read 42996 times)
Offline Jim G
  •  22 22
Re: Macro for inputs and outputs
« Reply #20 on: February 07, 2016, 04:17:26 PM »
have the damned pics small but it wont send them - keep getting some error about file names.
Renamed them and it still won't work...
My regular email is midwestcypress@gmail.com
Maybe we can figure this out directly  instead of on here?
« Reply #21 on: February 07, 2016, 07:19:42 PM »
Yep each picture that has ever been uploaded has to have a seperate name .  No duplicates allowed.
« Reply #22 on: February 07, 2016, 07:21:26 PM »
Try something for me . In your script change the word False to true and remove te sleep or reduce it down to say sleep(20). That will check the logic state.
Offline stirling
  •  2,188 2,188
  • UK
    • www.razordance.co.uk
« Reply #23 on: February 08, 2016, 05:51:46 AM »
Ok - been playing with it.
When I load your macro it doesn't wait for anything... just runs !
If by "just runs" you mean it turns the output on and then straight off, then you have a problem with your input signal. The first loop runs whilst the input is active and the second whilst it's INactive.
It therefore must be BOTH in quick succession. Either your input isn't doing what you think - or it's bouncing.
« Reply #24 on: February 08, 2016, 10:31:57 AM »
OK I will let Stirling take lead on this discussion ;)
Offline stirling
  •  2,188 2,188
  • UK
« Reply #25 on: February 08, 2016, 11:10:42 AM »
LOL - why thanks Terry BR549 - didn't know there was a concept of "lead" - nor that permission was needed.  :D
« Reply #26 on: February 08, 2016, 01:19:46 PM »
HIYA Ian not a problem here  8)    BUT it sometimes confuses teh person asking for help if 2 try to help at teh same time asking different questions.  ;)
There are plenty of questions to go around Unless RUSS is lurking about  >:D  Then it is every man for himself  ;D
Offline stirling
  •  2,188 2,188
  • UK
« Reply #27 on: February 09, 2016, 05:52:48 AM »
Terry - A good point well made. Apologies if I've confused things.
