Hello Guest it is November 13, 2026, 11:31:31 PM
Author Topic: Macro for inputs and outputs  (Read 43000 times)
Re: Macro for inputs and outputs
« Reply #10 on: February 06, 2016, 03:33:11 PM »
Repeats (;-) and YES it all works HERE including the M901 Mcode.
G0 G17 G40 G49 G80 G90
G91 (Set Inc Mode)
G0 X0 Y0
F600
M98 P001 L22 (Loop 22 times)
G0 X0 Y0
G90  ( Reset Abs Mode)
M30
o001
G1X5
M901 ( call driller, wait for signal)
M99
Offline Jim G
  •  22 22
« Reply #11 on: February 07, 2016, 09:50:17 AM »
On the overall movement thing - I do not have an encoder or dro....
But If I tell it to move 120" it moves 120" measured with a tape measure. In reality it probably moves a few thousands less. Seems like every step it loses just a bit and since we are doing a lot of steps it adds up .
The Macro works if I put in a sleep that is longer than the drill cycle and I do see that it is getting the input from the end of drill cycle..
Offline stirling
  •  2,188 2,188
  • UK
    • www.razordance.co.uk
« Reply #12 on: February 07, 2016, 10:03:00 AM »
Try this:
Code: [Select]
ActivateSignal(OUTPUT1)
while isActive(INPUT1)
  sleep 10
wend
while not isActive(INPUT1)
  sleep 10
wend
DeactivateSignal(OUTPUT1)
Offline Jim G
  •  22 22
« Reply #13 on: February 07, 2016, 10:15:50 AM »
Leave in the blank lines or not?
« Reply #14 on: February 07, 2016, 10:30:18 AM »
OK that tells me that the logic is not working IF the sleep is controlling the wait.
When your driller signals back that it is done does the led for input1 turn ON or turn OFF ?
In config for the input signal (inpout1) is it set for active high or active low. Can you show a picture of your setup in ports pins .
Also please post exactly what you have for teh M901 script. It works fine here when I test it.  We just need to get teh logic correct on your end.
« Last Edit: February 07, 2016, 10:32:00 AM by BR549 »
Offline stirling
  •  2,188 2,188
  • UK
« Reply #15 on: February 07, 2016, 11:06:12 AM »
Blank lines are completely irrelevant.
Just copy it and try it
Offline Jim G
  •  22 22
« Reply #16 on: February 07, 2016, 02:47:54 PM »
Ok - been playing with it.
When I load your macro it doesn't wait for anything... just runs !
More info in a few minutes.
Offline Jim G
  •  22 22
« Reply #17 on: February 07, 2016, 03:14:08 PM »
so how do I attach pics n videos?
« Reply #18 on: February 07, 2016, 03:19:18 PM »
Push the reply button then select additional options. Then use browse to point to the file you want to upload. Double check the size of your pictures (;-) keep them small if you can.
Offline Jim G
  •  22 22
« Reply #19 on: February 07, 2016, 03:26:53 PM »
they are too big.. .mmmm gotta get them smaller.. give me a minute
