Hello Guest it is November 17, 2026, 06:13:03 PM
Author Topic: How to use my mill as a lathe.  (Read 13895 times)
« on: May 14, 2007, 09:18:38 AM »
Machinists,
Using Mach 3, PMDX and Geckos on a Smithy CNC mill.
I have a project that would easily be done on a CNC lathe, but I don't have one (yet).
I need to cut a wave contour on the outside of a 2" diameter piece, 1" long.  I plan on chucking the piece into the R8 collet and cutting it with a lathe tool mounted on the table.
I am wondering how to go about writing code for this, suggestions for mounting a lathe tool on the table, and basically how it is done.
I can post a picture of the profile I'm needing if that will help.
Thanks in advance.
MM
ps:  I have no idea why I'm getting this funky text, using Mac OSX 10.3.9.?????
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
Re: How to use my mill as a lathe.
« Reply #1 on: May 14, 2007, 01:59:32 PM »
This is not hard to do, post some pictures and we will give you some pointers on how to do it.
Graham.
« Reply #2 on: May 14, 2007, 02:11:42 PM »
Here's the wave   I'm also wondering if using a ball end mill would work???.  THis wave has to go on the outside of a 2" dia x 1" deep cylinder, also the inside of a 2.5" dia x 1" hole, blind. thanks MM
www.newfangledsolutions.com
www.machsupport.com
« Reply #4 on: May 14, 2007, 10:04:59 PM »
or like this
http://www.youtube.com/watch?v=wbfXXeiSHsw
Cool - is that hand coded?
Mike
« Reply #5 on: May 15, 2007, 07:34:11 AM »
With a few fixture offsets it would not be to bad :)
I don't know who did that but it was not me ;)
www.machsupport.com
