Hello Guest it is November 10, 2026, 01:56:31 AM
Author Topic: Doing something wrong  (Read 7460 times)
« on: January 25, 2016, 10:21:17 PM »
I have the following attached to a button...code seems like it should work, i created two dros, OEM1300 and OEM1302, get a data type mismatch. When I step thru with the debugger, I am getting the correct values into XPos and YPos...can't figure what I am doing wrong..
Sub Main
   XPos=GetOEMDRO(1300)
   YPos=GetOEMDRO(1302)
      Code "G0 X" + XPos + "Y" + YPos
End Sub
Re: Doing something wrong
« Reply #1 on: January 25, 2016, 10:30:09 PM »
Try this
Code "G0 X" & XPos & "Y" & YPos
Offline stirling
  •  2,188 2,188
  • UK
    • www.razordance.co.uk
« Reply #2 on: January 26, 2016, 04:06:41 AM »
Ah the stupid overloading of the + op in VB and the like.
Here's the official word from MS
Differences Between the Two Concatenation Operators
The + Operator (Visual Basic) has the primary purpose of adding two numbers. However, it can also concatenate numeric operands with string operands. The + operator has a complex set of rules that determine whether to add, concatenate, signal a compiler error, or throw a run-time InvalidCastException exception.
The & Operator (Visual Basic) is defined only for String operands, and it always widens its operands to String, regardless of the setting of Option Strict. The & operator is recommended for string concatenation because it is defined exclusively for strings and reduces your chances of generating an unintended conversion.
Here's what that actually means:
Look - we screwed up - ok?. We made TWO concat operators because we're dumb. Worse we made one that works always and one that sometimes doesn't. Just use the & ok.
« Reply #3 on: January 26, 2016, 05:55:26 AM »
Thanks! I should have known that from my previous programming experience!
