Hello Guest it is November 13, 2026, 03:15:47 PM
Author Topic: On screen interface - Axis 4  (Read 11640 times)
Offline Lubby
  •  25 25
« on: January 25, 2016, 02:23:11 PM »
I'm looking for some help getting an on-screen visual of a fourth axis coordinates.
I've added a fifth motor to my setup under Axis B ( with Axis A being slave to X )
I'd like to be able to visually locate the changes in coordinates of this additional motor in the Axis 4 coordinate bar.
( as in the box between the 'Zero 4' button and Radius Correct, in the Program Run tab )
I can find this in the REF B of the Diagnostics tab but cannot locate it elsewhere.
How can I configure things to register the movements of Axis B within this box?
thanks
Re: On screen interface - Axis 4
« Reply #1 on: January 25, 2016, 03:22:02 PM »
You need to edit the screen and change the DRO from the A axis to the B axis.
Offline Lubby
  •  25 25
« Reply #2 on: January 25, 2016, 09:50:51 PM »
I think I'd need to load in a new ( downloaded ) screen for this or build my own in a screen designer program?
Looks like Mach 4 enables editing within the program but from what I can find I'll need to download or develop a new screen.
Appreciated
  •  9,377 9,377
« Reply #3 on: January 26, 2016, 12:51:22 AM »
You can change your existing screen (as Gerry has said) to replace the A axis DRO with a B axis DRO (It takes a bit of learning but it is not difficult to do). Alternately you could download and use a 6 axis screen set.
The various Screen sets and the Screen editors are here;   http://www.machsupport.com/software/downloads-updates/screensets/
« Reply #4 on: January 26, 2016, 06:02:27 AM »
Are you using Mach3, or Mach4?
Offline Lubby
  •  25 25
« Reply #5 on: January 26, 2016, 07:51:04 AM »
Mach3.
I'll try out the Six Axis screen.
Appreciated.
