Hello Guest it is November 10, 2026, 01:58:30 AM
Author Topic: GetSelectedTool() not working for Mach3 lathe  (Read 7489 times)
« on: January 21, 2016, 11:40:00 AM »
Help
I am partway through a project getting my 8 station tool turret up and running and now I'm stumped.
So far the turret is working mechanically and when I press a button a short macro controls it so that
it indexes one position. At the same time a Brain program reads 4 sensors compares against truth table
then outputs the current tool. All that appears to be working fine.
The next step of the project was to make it fully automatic with all the indexing controlled from M6start macro.
I thought it would be a relatively straightforward extension of my initial program. Apparently not.
After some investigation I identified where the program was failing. It wasn't reading the selected tool !!!
I have whittled the program down to the minimum just to test this function
 (M6Start.m1s)
Dim tool As Integer
tool = GetSelectedTool()
Message   " Requested   Tool     " & tool '  just a test output to check function read
As a test when I type for example    M6  T4     into the MDI line    I was expecting to get
Requested Tool  4          instead I get         Requested Tool     0    and the current tool DRO also changes to  '0'
I have tried  on mach3 mill and it works as expected  but not on mach3 lathe
For information
I have  CONFIG - TOOL CHANGE-  set to   Auto tool changer
tried on versions  R3.043.066  and R3.043.052   with three different lathe screen sets
I have looked through the forum and cannot see   this flagged up as a recurring fault
and considering the amount of lathe tool turrets there are out there is must be something I am doing wrong
Any help would be greatly appreciated
cheers George
ps I have also tried removing the brain program from the equation but result is just the same
Re: GetSelectedTool() not working for Mach3 lathe
« Reply #1 on: January 21, 2016, 04:13:12 PM »
YOu are using teh wrong tool change fornat for turn. Mill is M6 T1 for tool 1  and turn is M6 T0101 for tool 1.
« Reply #2 on: January 22, 2016, 12:27:05 PM »
Brilliant , That's it. It works now.
Can't tell you how long I have spent swearing at program
commanding it to work. Life is good again.
Thanks BR549 for your help
Have a great weekend
George
