Hello Guest it is November 13, 2026, 12:31:24 PM
Author Topic: The Router starts only with Plasma profile  (Read 6788 times)
« on: January 19, 2016, 05:02:42 AM »
Hello guis, I have a question about my CNC.
I made a router with a 3 axis TB6560 driver board. When I input the XYZ axis pins and ports everything starts and works well.
But, when I restart the computer, I am able to turn on the CNC only when I start Mach3 Plasma profile. I need to start it, close it and then when I start the normal Mach3 Mill profile, everything works fine.
I can not figure where the problem must be - in the port and pins config section, general config or ... I don't know.
