Hello Guest it is November 22, 2026, 08:49:45 AM
Author Topic: How to change the screen that Mach 4 starts with  (Read 8879 times)
« on: January 17, 2016, 02:26:08 PM »
How do I change the screen that Mach 4 starts with?  Do I manually edit the .ini file or is there some more GUI way to do it?
Offline DazTheGas
  •  778 778
  • DazTheGas
Re: How to change the screen that Mach 4 starts with
« Reply #1 on: January 17, 2016, 02:37:49 PM »
Go into your screen editor and put the screen on the screen you would like to start in, then you will need to change something trivial then quit out of the screen editor and save. you should now startup in that screen.
DazTheGas
« Reply #2 on: January 17, 2016, 03:01:46 PM »
So if I am starting in wxMach and I want to use wx4 instead, where do I do this?  If I right click on the screen name in the screen editor, and click import, it asks for a screen container file.  I don't see those files anywhere and I don't know if that is what I need to do.
Offline DazTheGas
  •  778 778
  • DazTheGas
« Reply #3 on: January 17, 2016, 04:33:02 PM »
oh i see what your asking now, from the mach4 main menu you need to click on View->Load Screen then navigate to the screens directory and pick the screen you want.
DazTheGas
