Hello Guest it is November 22, 2026, 08:38:08 AM
Author Topic: M6 Manual tool change with Mach 4  (Read 11686 times)
« on: January 17, 2016, 02:24:53 PM »
I have the m6.mcs macro from the examples in my profile's macro folder, but the machine isn't stopping on M6.  What do I need to do?
Offline DazTheGas
  •  778 778
  • DazTheGas
Re: M6 Manual tool change with Mach 4
« Reply #1 on: January 17, 2016, 04:35:04 PM »
If you have a quick look through the Mach4 forum you will find many topics on this with many different answers to different situations.
DazTheGas
« Reply #2 on: January 17, 2016, 05:56:40 PM »
I appreciate the tip but I have taken quite a long look through the forum and the internet for an answer and I think I'm not a bad looker.  I believe I have followed the instructions regarding how to do this and it seems quite simple.  Despite that it doesn't work.
Offline dude1
  •  1,253 1,253
« Reply #3 on: January 17, 2016, 07:06:31 PM »
that is a known problem, if you have sim in the plugin folder remove it, run as admin, failing all that do a clean reinstall as admin. if all this fails you have a dependency missing
« Reply #4 on: January 17, 2016, 08:08:50 PM »
The problem was what Daz mentioned in a different thread - the function name in the example(!) is in lower case and it has to be in upper case to work (M06 instead of m06).  I wonder how many people get tripped up by this...  Thanks for the help.
Offline dude1
  •  1,253 1,253
« Reply #5 on: January 17, 2016, 10:31:11 PM »
cool forgot that one
