Hello Guest it is October 24, 2026, 12:45:42 PM
Author Topic: CSMIO-ENC Spindle Orientation  (Read 229889 times)
Offline TPS
  •  2,627 2,627
Re: CSMIO-ENC Spindle Orientation
« Reply #80 on: July 27, 2019, 06:50:32 AM »
ok, that means the Motor Controller tunning is OK.
have you tryed to reduce the spindle acceleration/deceleration in CSMIO plugin Setup ?
6000rpm/s is pretty high.
Offline Davek0974
  •  2,606 2,606
« Reply #81 on: July 27, 2019, 06:59:39 AM »
Will try that now
Offline Davek0974
  •  2,606 2,606
« Reply #82 on: July 27, 2019, 07:37:29 AM »
Hmm,
I have been conversing a lot with member lion_rapid, great guy as you all are ;)
We have managed to get the spindle tuned now, also I can get orientation to work perfectly in the CSMIO plugin config page. I have it set so I can insert a locking pin into my spindle shaft to allow me to unlock collets etc.
BUT
In M3/M5 and M20 calls orientation fails every time, M20 throws up angle errors every time. Having "stop at position" turned on in config  just makes the spindle stop at random locations every M5 call.
Baffled now - so near but so far away ;)
Offline TPS
  •  2,627 2,627
« Reply #83 on: July 27, 2019, 08:13:55 AM »
ok did a Little bit of reading about M20.
from the Manual (https://www.en.cs-lab.eu/technical-support/download/addons-macros/macro-m20-for-spindle-positioning/)
1.Settings:
a.Using M20 macro for spindle positioning, you can’t use „Align at stop” function at the same time (plugin „Spindle” tab) and reversely
3. The M20 macro verifies the set and real position after spindle positioning.
If the difference between those two values is higher than „Const Offset = 1” parameter value, the „M20 ERROR Offset !!!„ error will appear.
The „Const Offset” value can be reasonably adjusted to our needs (the value of 1 is usually optimal).
that means you can "Play" (increase) a bit with the
Const Offset = 1
in M20.M1S macro.
btw:
how did you do this?
« Last Edit: July 27, 2019, 08:15:42 AM by TPS »
Offline Davek0974
  •  2,606 2,606
« Reply #84 on: July 27, 2019, 09:22:36 AM »
Yes i read the bit about the M20 and align at stop, i have turned off AOS but M20 still fails.
The get it to work in config all we did was tune the servo better. I have no idea what to look for but lion_rapid did, we went through it on the phone and it runs much better now, apart from this M20 thing.
Offline TPS
  •  2,627 2,627
« Reply #85 on: July 27, 2019, 09:55:59 AM »
and what angledifference does the M20 errormessage Show?
Offline Davek0974
  •  2,606 2,606
« Reply #86 on: July 27, 2019, 02:44:13 PM »
Different error every time, can't see any pattern to it at all.
It's bugging me that it works 100% in the config window, but 0% in Mach3 - makes me think it could be a Mach3 or Interface problem, it wouldn't be the first one  ;)
Offline TPS
  •  2,627 2,627
« Reply #87 on: July 28, 2019, 06:14:54 AM »
well sounds like it is time to contact CS Lab.
Offline Davek0974
  •  2,606 2,606
« Reply #88 on: July 28, 2019, 06:40:25 AM »
Yep,
I have an ongoing chat with a guy there, i have forwarded this last bit info to him.
Usually takes a week or two for a reply  :(
At least it proves it can work.
Offline Davek0974
  •  2,606 2,606
« Reply #89 on: October 03, 2019, 05:55:29 AM »
CS-LAB have found the issue :)
In the CS-MIO plugin config, under spindle axis, do not use "reversed direction" - there is a firmware bug that stops spindle alignment working :)
I had to untick that box, tick "encoder reversed direction" and also reverse the motor direction inside the servo drive itself.
All working now, very accurate and also with the shared encoder ( i didn't tell them that though ;) )
