Hello Guest it is October 30, 2026, 08:50:55 AM
Author Topic: CSMIO-ENC Spindle Orientation  (Read 232121 times)
Offline TPS
  •  2,627 2,627
Re: CSMIO-ENC Spindle Orientation
« Reply #30 on: April 24, 2019, 11:03:34 AM »
i have also linked my Encoder Output from spindle servo to c axis and ENC module.
but i am doing the spindle orientation (for the ATC) on the servo drive, this is enabled
by a digital Input on the servo and reported back by a digital Output from the servo.
Offline Davek0974
  •  2,606 2,606
« Reply #31 on: April 24, 2019, 11:15:28 AM »
So using the encoder signal twice does actually work?
From the vague replies i get from CSL its not to be done at any cost ;) But i guess maybe that would affect sales of ENC modules ??
I will be trying this, my encoder will also be sharing the ENC channel1 input between main spindle and 4th axis spindle, i won't be doing dual spindle stuff so its either one or the other. I'll do the switching with a 74LS257BN quad channel, dual input switch IC, could have used relays but thats messy i think.
« Reply #32 on: July 13, 2019, 04:13:55 PM »
Yes, you can parallel the signal. Works on my setup.
Offline Davek0974
  •  2,606 2,606
« Reply #33 on: July 14, 2019, 01:20:03 AM »
Yes I can confirm it does works very well, for threading at least.
I still can't get spindle orientation to work properly - it does stop at a location, it will creep back to a location if needed, trouble is that the location it chooses is not the same each time?
Yes the encoder is 1:1 with the spindle and threading does work very well.
« Reply #34 on: July 14, 2019, 03:44:50 AM »
Do you have an index signal in your spindle encoder?
Offline Davek0974
  •  2,606 2,606
« Reply #35 on: July 14, 2019, 04:07:37 AM »
Yes, it uses the index for threading sync as far as i know.
« Reply #36 on: July 14, 2019, 04:08:36 AM »
So threading works, but orienting the spindle doesn't?
Offline Davek0974
  •  2,606 2,606
« Reply #37 on: July 14, 2019, 04:12:38 AM »
Yep thats it.
No error messages, it will creep to a stop each time but that stop is different :)
« Reply #38 on: July 14, 2019, 04:14:33 AM »
Which way do you orient the spindle? By setting in the plugin or M20?
Offline Davek0974
  •  2,606 2,606
« Reply #39 on: July 14, 2019, 04:18:47 AM »
Only tried the plugin, didn't know about M20?
