Hello Guest it is November 22, 2026, 08:31:52 AM
Author Topic: probing with Mach4??????  (Read 15681 times)
« on: January 15, 2016, 01:37:00 PM »
I have mach4 up and running with a hicon board, I have my probe working,( LED lights up when activated, ) I have motin, ( I can run gcode) but when I go to the probing page, and click measure Z
I get a ERROR: invalid gcode. I have searched and researched but I can not figure out how to get this to work. I can do a g31 z-5 f10 and that works as well. it seems to be something wrong with the measure z?????  mach 4 ver 4.2.0.2803
I coiuld use some help or a place to start looking
thanks
jerry
Offline DazTheGas
  •  778 778
  • DazTheGas
Re: probing with Mach4??????
« Reply #1 on: January 15, 2016, 01:49:16 PM »
on the probing screen, have you configured the settings tab and added the gcode 31 to it.
DazTheGas
« Reply #2 on: January 15, 2016, 02:16:36 PM »
yes i have,  it worked (kind of) once,the first time I added the 31 to gcode box the Z started moving but in the wrong direction.
The next time I got an error no contact with probe.
« Reply #3 on: January 15, 2016, 02:47:12 PM »
ok I have got it to work i had to give it a z poistion of -5 but it is probing, I can't seem to find the place to give it my touch plate height??
Offline Pedio
  •  200 200
« Reply #4 on: January 16, 2016, 08:39:52 AM »
See this thread for help http://www.machsupport.com/forum/index.php/topic,31367.30.html
There is also another one called "Auto Tool Zero" that might help. It talks about screensets to use as the basis.
Offline DazTheGas
  •  778 778
  • DazTheGas
« Reply #5 on: January 17, 2016, 04:49:48 PM »
The easiest way to do it in mach4 is to use the probing screen and use the measure z, once the probe has touched you can then switch over to the offsets tab where you will find a box for your gauge height and set z
DazTheGas
« Reply #6 on: January 18, 2016, 08:41:40 AM »
I tried that but I keep getting unexpected results I must not have the correct settings or procedure. every time I probe it keeps setting my g54 z in the fixture table. but never give me the correct z in the dro
Jerry
Offline DazTheGas
  •  778 778
  • DazTheGas
« Reply #7 on: January 21, 2016, 01:44:20 PM »
Jerry
In the top right set this on measure only before you start the probe
DazTheGas
