Hello Guest it is November 13, 2026, 05:55:48 PM
Author Topic: Homing Axis Using Encoder Index Pulse  (Read 11114 times)
« on: January 10, 2016, 01:41:25 PM »
I am looking to use the Pokeys57CNC board as a motion controller for a lathe to upgrade from parallel port. I have looked over the documentation but have not seen how to set the home position using the encoder index pulse after a homing switch is contacted. I would like to have the homing be as accurate as possible, thus would like to be able to set to the encoder index.  I am currently using Mach 3 Turn but would move to Mach 4 if this homing sequence were available in a plugin. If it is not done from the plug in, please recommend the best method for such homing of an axis.
Thanks, Jim
Offline NeoTO
  •  504 504
    • PoLabs
Re: Homing Axis Using Encoder Index Pulse
« Reply #1 on: March 07, 2016, 10:41:10 PM »
Hi, Jim
Homing using encoder index pulse is not yet supported, but we are looking into implementing it soon.
Matevž, PoLabs
