Hello
Guest
it is
October 20, 2026, 02:54:47 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
arcs gone wild
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: arcs gone wild (Read 13653 times)
stirling
2,188
UK
arcs gone wild
on:
May 12, 2007, 02:55:11 AM »
Hi all
Has anyone come accross the problem of Mach3 getting the centre of G02 G03 arcs a country mile out? I have a simple toolpath to cut out a rectangular profile. Each corner (of the toolpath) is an arc which should have a radius of around 7mm according to the g-code. However Mach3 interprets the radius to be massive so I end up with a toolpath resembling a rectangle with huge "micky mouse" ears!!!
Sorry - can't seem to figure out how to attach images code etc...
Any comments, advice would be welcome.
Logged
Razordance Torch Height Control
Graham Waterworth
2,785
Yorkshire Dales, England
Re: arcs gone wild
Reply #1 on:
May 12, 2007, 03:00:47 AM »
Go into gen config and change the IJ mode, that should fix it.
Graham.
Logged
stirling
2,188
UK
Re: arcs gone wild
Reply #2 on:
May 12, 2007, 03:43:08 AM »
Many thanks Graham - problem solved - strange though, havn't had this happen before... Though I have just reloaded Mach3, but can't remember setting this before.
Anyway thanks again for your quick and spot-on reply
Logged
chad
361
When the going gets weird, the weird turn pro.
Re: arcs gone wild
Reply #3 on:
May 14, 2007, 03:29:54 AM »
And also don't forget your cam program can toggle this also.
Chad
Logged
stirling
2,188
UK
Re: arcs gone wild
Reply #4 on:
May 14, 2007, 04:14:16 AM »
thanks chad - right on the money.
I'd switched off "output arcs as linear segments" in my CAM (RhinoCAM) which meant this was the first time I'd actually posted a real arc (G02 and 3) so this was the first time Mach3 cared about this setting.
Thanks both for your help
Logged
Omega_Sam
18
Re: arcs gone wild
Reply #5 on:
January 21, 2008, 01:50:37 AM »
Thanks for this thread, I was having the same problem posting from Gibbs. Switching the IL buttons fixed that.
Omega_Sam
Logged
Print
Pages:
1
Go Up
« previous
next »
