Hello Guest it is November 24, 2026, 09:59:23 PM
Author Topic: Problem with round letters  (Read 16227 times)
« on: January 08, 2016, 06:11:46 AM »
Hi!
Im drawing in CorelDraw, than I create toolpath in ArtCAM which I use on MACH3.
Im using EndMill 2mm.
Mach 3 settings:
Velocity: 600
Acceleration: 140
My problem is that machine causes those weird errors on round letters like you can see on pictures.
Some of letters like ''D'' are perfectly shaped in the other hand there are lettery ''O'' and ''F'' with those errors.
I tryed changing velocity and acceleration  but problem stays the same.
Does anyone know how to solve this problem ?
Please help!
Good letter:
Bad letters:
Offline Davek0974
  •  2,606 2,606
Re: Problem with round letters
« Reply #1 on: January 08, 2016, 06:17:15 AM »
Is there any backlash in either of the axes??
« Reply #2 on: January 08, 2016, 06:56:02 AM »
Here, I uploaded a video of a working machine, so check it out.
https://youtu.be/zTNxxEgkmW4
  •  9,378 9,378
« Reply #3 on: January 08, 2016, 06:59:47 AM »
There appears to be a lack of rigidity with your machine - perhaps tool flex, perhaps axis flex, perhaps backlash (as Dave has suggested).
Maybe more passes with shallower depth of cut, reducing the tool loading, would help.
« Reply #4 on: January 08, 2016, 07:11:06 AM »
How to reduce tool loading ?
I dont think more passes with shallower deoth of cut would help, cause I tryed it already.
Offline Davek0974
  •  2,606 2,606
« Reply #5 on: January 08, 2016, 08:43:10 AM »
To reduce tool loading, run at a lower speed on the X/Y
Or increase tool speed/rpm but only of course if the tool/material can take it
Offline rcaffin
  •  1,073 1,073
« Reply #6 on: January 10, 2016, 03:42:06 AM »
Yup, and possibly both flex and backlash.
You may have run into a limit of what your machine can handle.
Roger
Offline Davek0974
  •  2,606 2,606
« Reply #7 on: January 10, 2016, 04:58:02 AM »
What machine is this?
A plasma table?
Wood routing table?
Other?
It's not a milling machine thats for certain;)
« Reply #8 on: January 10, 2016, 06:31:49 AM »
Try ramping in rather than plunging.
« Reply #9 on: January 10, 2016, 08:09:48 PM »
Also varify that you are useing tools that are end cutting. There are those that are NOT.  Also try a tool that has a point or a ball end. That coul dhelp take out some of those forces that tend to push and pull your backlash or flex around.
Just a thought, (;-)TP
