Hello Guest it is November 01, 2026, 12:17:47 PM
Author Topic: What is the projected cost of LazyCAM  (Read 75887 times)
« on: March 09, 2006, 11:09:18 AM »
Also will you support cutter compensation?
-James
Re: What is the projected cost of LazyCAM
« Reply #1 on: March 09, 2006, 07:13:35 PM »
Hello James
There is Comp now :) and that is in version that comes with Mach3/IV
thanks
Brian
www.newfangledsolutions.com
www.machsupport.com
Offline peu
  •  26 26
« Reply #2 on: March 10, 2006, 09:14:22 AM »
when is the new beta version expected to be released? I cant pass the initial screen, every dxf I try crashes it
« Reply #3 on: March 10, 2006, 10:05:58 AM »
Hello James
thanks
Brian
Hi Brian,
The reason I want to know the ultimate cost (if any) is that I am writing a musical instrument inlay design package that runs on top of CorelDraw 12.  I am currently supporting Dolphin Cad/Cam and working to support SheetCAM.  LazyCAM looks like a real winner for my application especially since SheetCAM does not have cutter comp yet.
Will LazyCAM have an object model so that I can directly manipulate the setup and import of a DXF file from my VBA code?  I would like to be able to directly set all the parameters etc so that I can command the CAM module directly without the UI if possible
BTW I am an avid Mach user and a Mach1 beta license holder, so I have been around for a while.
-James
« Reply #4 on: March 10, 2006, 10:56:00 AM »
I think in the end that could be setup to do that :)
www.machsupport.com
« Reply #5 on: March 10, 2006, 11:25:16 AM »
James, why don't you just output g-code from Corel using VBA? I do it with AutoCAD, and am able to put G41 and G42 in the code from VBA. I export ready to run g-code from within AutoCAD using VBA.
« Reply #6 on: March 10, 2006, 01:08:41 PM »
Hi Gerry,
Yes, I am going to do that for simple cases such as fingerboard slotting and fixturing.  For complex multi-tool pocketing I want the support of a CAM package, at least for now.  I don't have the time at the moment to deal with tool tables, finish passes etc.  Maybe version 2.  I currently have a custom DXF export I wrote in VBA to deal with some of CorelDraw's deficiencies in the V12 DXF export they do now.  ;)
-James
