Hello Guest it is November 13, 2026, 07:46:47 PM
Author Topic: Strange Axis movement  (Read 13432 times)
« on: December 31, 2015, 08:55:47 AM »
Setting up a new controller, and i noticed that all axis don't return to the same position that the left from.  For example
Starting at 0
G0
X 5"
X-5" (expecting to be at 0)
But ending at -2" on both x and y axis.
Any ideas?
Re: Strange Axis movement
« Reply #1 on: December 31, 2015, 09:13:50 AM »
Are you sure that you're in incremental mode?
When you do X 5, does it go to 5?
Either your steps/unit is wrong, or you're losing steps.
« Reply #2 on: December 31, 2015, 09:21:29 AM »
It will move out in one direction 5" but return in a different measurement.
In the General Logic Config Panel, the distance mode is Absolute, and IJ in Inc.
Need to learn more about it. Still in learning mode lol
« Reply #3 on: December 31, 2015, 09:24:20 AM »
In Absolute mode, this should end up at -5, moving 10"
« Reply #4 on: December 31, 2015, 09:36:07 AM »
 Should I normally be in Abs or inc mode or is that not a simple question to answer?
« Reply #5 on: December 31, 2015, 09:47:30 AM »
Spending some time watching some videos and researching this more.
Thank you for your help :)
« Reply #6 on: December 31, 2015, 09:48:19 AM »
Most people use absolute most of the time.
But each has their place.
« Reply #7 on: December 31, 2015, 10:01:01 AM »
Like anything else, the more we know, the more we find that we don't know :)
Thanks again.
