Hello Guest it is November 13, 2026, 07:47:08 PM
Author Topic: Has to be a record (way too funny)  (Read 25618 times)
Re: Has to be a record (way too funny)
« Reply #10 on: December 29, 2015, 03:39:18 PM »
I forgot to add I gave him the Gcode as well, but he would not try and run it.
Try not to get discouraged.
« Reply #11 on: December 29, 2015, 04:00:52 PM »
Given the number of Mach3 installations giving good stable service I can't understand why so many muppets insist on assuming that it can't be their config or hardware based on a knowledge level of approximately zero  ???  ???
Offline dude1
  •  1,253 1,253
« Reply #12 on: December 29, 2015, 06:34:57 PM »
yer it's mostly the It guys that do it there response is always the same I have been using computer for X amount of years and I work in IT, what means nothing it's cnc not IT, it's even worse when they argue with admin and the guys that have been doing cnc for 50 years.
it's bad when you have to make them fail to see they are wrong.
but that's life or that's humans for ya
« Reply #13 on: December 29, 2015, 06:53:46 PM »
Geez you used to be able to load a DXF into mach2 and have it run what happened???
Sometimes you forget to ask one of the 20 questions up front and you get knee deep into the problem before you realize it has NOTHING to do with Mach3. It is one of those head slap moments.
  •  9,377 9,377
« Reply #14 on: December 30, 2015, 03:30:34 AM »
LazyCam ??
« Reply #15 on: December 30, 2015, 08:42:21 AM »
OH NO  alot earlier that that.  I still have a copy.  It also did bmp imports.
« Reply #16 on: December 30, 2015, 08:48:04 AM »
It was much better than LazyCAM, imo. :)
