Hello Guest it is October 10, 2026, 12:47:22 PM
Author Topic: Charge Pump Issues (Blade Runner II & Mach 3)  (Read 13413 times)
« on: December 28, 2015, 07:20:38 AM »
I was given a profile per the company I bought my machine from so that I would not have to mess with ports and such, but I CAN hit RESET and make the Light on the screen go green, Motors are locked and cannot be moved but I cannot get the Charge Pump LED to come on, on the UBOB.  I have no errors on the screen and when I plug in the Parallel port adapter The light flashes for a second then goes off.
Here are some images from last nights trouble shooting.
« Last Edit: December 28, 2015, 07:22:37 AM by Dugan »
  •  9,374 9,374
Re: Charge Pump Issues (Blade Runner II & Mach 3)
« Reply #1 on: December 28, 2015, 09:47:51 AM »
Parhaps if you reduce the size of your images (to 800 pix width) and post them using the Additional Options we can all get to see them.  ;)
« Reply #2 on: December 28, 2015, 09:52:36 AM »
Ah sorry, Didnt know they wouldnt come up lemme delete them and redo it
Also cant edit the first post.
Its saying I have already posted the first 4 images, do image posts have to be checked by a mod?!?!  This is the most confusing forum setup ive ever used...
« Last Edit: December 28, 2015, 10:03:28 AM by Dugan »
« Reply #3 on: December 29, 2015, 08:00:02 AM »
Ended up being a failed parallel port driver, Re-ran the install and it works great now.  I have no idea how it failed the first time.
  •  9,374 9,374
« Reply #4 on: December 29, 2015, 01:14:48 PM »
Each image has to have a unique name (an image with a particular name cannot be posted more than once).
No. But as I said it is best to use the Additional Options tab to post the image.
Give it time you will soon master it.  ;)
I am pleased that you have it sorted.
« Reply #5 on: December 29, 2015, 01:22:41 PM »
The weird part is the images I posted have a different name than those I was trying to post, I had to save them from my Google account.
  •  9,374 9,374
« Reply #6 on: December 30, 2015, 01:29:58 AM »
The particular image name may have been used by someone else in the past (stranger things have happened  ;D )
