Hello Guest it is November 17, 2026, 01:58:48 PM
Author Topic: Using f engrave  (Read 25637 times)
Re: Using f engrave
« Reply #10 on: December 28, 2015, 08:13:04 PM »
Yes, I learned something about fonts.  I will give the normal a try using a dremel engraving bit and my v bits to see what happens
Re: Using f engrave
« Reply #11 on: October 28, 2016, 08:53:41 AM »
I just started my first try with fengrave...i am doing a cleanup pass after and for some reason is does not line up properly with the first v cut pass
it looks almost like it needs to offset more by the amount radius of the bit
i overlaid the cleanup pass in magenta on top of the vcarve for reference to see what i mean.
I cut my first vcarve pass, loaded the clean up pass leaving my x and y origin untouch and simply rezeroed .
has anyone else experienced this?
