Hello Guest it is November 14, 2026, 12:27:25 AM
Author Topic: Edit post for xy position move then z  (Read 24852 times)
« on: December 25, 2015, 04:33:43 PM »
This is what my gcode is coming out like:
G90G80G20G49
G0Z0.1000
G0 X-0.5662 Y0.9343 Z0.1000
G1   Z-0.1250 F30
I would like it to come out like this:
G90G80G20G49
G0 X-0.5662 Y0.9343
G0Z0.1000
G1   Z-0.1250 F30
This is what my post looks like:
; Set up program header
START = "([FILENAME])"
START = "(Material Size) (X=[XSIZE], Y=[YSIZE], Z=[ZMATERIAL])"
START = "(Tool Number:[T]) ([TOOLDESC])"
START = "G90G80G20G49"
START = "G0[ZH]"
; Program moves
FIRST_RAPID_RATE_MOVE  = "G0 [X] [Y] [Z]"
FIRST_FEED_RATE_MOVE   = "G1 [X] [Y] [Z] [F]"
FEED_RATE_MOVE         = "[X] [Y] [Z]"
FIRST_CW_ARC_MOVE      = "G2 [X] [Y] [J] [F]"
CW_ARC_MOVE            = "G2 [X] [Y] [J]"
FIRST_CCW_ARC_MOVE     = "G3 [X] [Y] [J] [F]"
CCW_ARC_MOVE           = "G3 [X] [Y] [J]"
NEW_SEGMENT_POST_TOOLCHANGE= "(Tool Number:[T]) ([TOOLDESC])"
NEW_SEGMENT_POST_TOOLCHANGE= "M3 [S)"
; End of file
END = "G0[ZH]"
END = "G0[XH][YH]"
END = "M30"
; M30 = program end and rewind
I have tried a bunch of different codes and i cant get it to post like i wans
Im sure its an easy fix.  Any help would be appreciated
« Last Edit: December 25, 2015, 04:35:54 PM by Programinator »
Re: Edit post for xy position move then z
« Reply #1 on: December 25, 2015, 06:43:30 PM »
Are you SURE you want to do it that way ??. Normally you would want to FIRST move to Z rapid height THEN move in XY to teh start position then lower Z at feedrate to start.
That is what your first example is doing.
IF you first MOVE in XY without lifting Z to rapid clearnace you could easily tear something up if you hit something with teh tool. The Machine has NO idea where anything is so that is teh reason you would move it to a safeZ height BEFORE teh XY moves.
What Cam program is that ?  I can guess what to change but easier and safer to just look it up then you are sure.
Just a thought, (;-) TP
« Reply #2 on: December 25, 2015, 07:28:58 PM »
Yes im sure this is what i want.  I always start my program with the tool above the part.  For my way of doing things this is way better.  Let me know if you have any ideas on how to change it and i can test it out.
Its for artcam
« Reply #3 on: December 25, 2015, 07:45:58 PM »
This is just a best guess , see what it does.
;START = "G0[ZH]"
; Program moves
FIRST_RAPID_RATE_MOVE  = "G0 [X] [Y] "
; End of file
END = "G0[ZH]"
END = "G0[XH][YH]"
END = "M30"
« Reply #4 on: December 25, 2015, 07:49:46 PM »
Artcam HAS a post configuration manual have you read it ??
« Reply #5 on: December 25, 2015, 07:59:40 PM »
Try this, but I'm with terry, you should leave it like it is.
; Program moves
FIRST_RAPID_RATE_MOVE  ="G0[ZH]"
« Reply #6 on: December 25, 2015, 08:42:33 PM »
;START = "G0[ZH]"
; Program moves
This code posts like this:  Not the result i need.  i will try the other suggestion now
THanks for trying
(text)
(Material Size) (X=39.370, Y=9.840, Z=1.500)
(Tool Number:1) (0.250 inches dia. slot drill)
G90G80G20G49
G0 X-0.5662 Y0.9343
G1   Z-0.1250 F30
« Reply #7 on: December 25, 2015, 08:45:38 PM »
The second suggestion fails to post.  "Duplicate statement found"
THanks for trying
any other suggestions
« Reply #8 on: December 25, 2015, 08:56:51 PM »
Try this:
; Program moves
« Reply #9 on: December 25, 2015, 10:25:54 PM »
Well this is what i ended up doing.  a machine coordanate move to z-.1 then xy to work offset move then z
I like it like this because i change tools manually off the part on the xy and if i had a move to z.1 first then xy it will hit clamps.
This way i dont have to worry about it.
I dont understand why the way you guys suggested will not work.  But this way will do the trick
Thanks for your help
START = "G90G53Z-.1"
START = "G0[XH][YH]"
START = "G0[ZH]"
; Program moves
« Last Edit: December 25, 2015, 10:27:56 PM by Programinator »
