Hello Guest it is November 22, 2026, 07:16:43 AM
Author Topic: Limit switch issues  (Read 208920 times)
Re: Limit switch issues
« Reply #140 on: December 28, 2015, 10:41:42 AM »
Enabled the limits, after I asked and he told me that they were, even though they were not. :)
  •  9,378 9,378
« Reply #141 on: December 28, 2015, 10:55:47 AM »
Thanks Gerry,
That is exactly what you asked him in reply #2 (he could have saved 14 pages of other peoples time).
« Reply #142 on: December 28, 2015, 11:13:06 AM »
Hi Mike,
So what exactly is it that you have done to cure the problem ??
enabled the limit switches, configured them correctly, enabled the home switches and configured them correctly, move the Y homing switch to the logical location, reversed the homing of the x axis so it moves in the right direction, enabled the z axis limit switch, enabled automatic limit override so I can easily move off the limit switch.....I think that's about it....
« Reply #143 on: December 28, 2015, 11:28:06 AM »
I know I shouldn't feed the trolls but show me by quoting my post where I said specifically in answer to you that the limit switches were enabled? I went to the 4th page and couldn't see where I answered YOU about limit switches.....
Furthermore, I really didn't care about limiting the travel of my axis, I was more concerned about homing....
Even after enabling the switches, as the HELPFUL user Stew pointed out, I still had issues with them going the wrong way and grinding into the limits...
If the two of you want to rag on about how much of YOUR time I wasted, no one forced you to read these posts....you could have skipped out 14.5 pages ago....I think ger21 just likes to prove to people how superior he is.....
You see, I have thanked those who helped me work out the issues, and personally thanked stew for his  help in a personal message....if you don't want to help, then don't...
  •  9,378 9,378
« Reply #144 on: December 28, 2015, 11:38:37 AM »
Mike,
I think you have a major attitude problem - I take exception to you calling members of this forum Trolls. Perhaps an apology from you would be in order.
Have you actually purchased a Mach3 license in you own name or are you continuing to use somebody else's license file. ??
  •  9,378 9,378
« Reply #145 on: December 28, 2015, 11:59:14 AM »
Just a heads-up...
Until such time as Mike's license situation has been satisfactorily resolved with NFS he has been excluded from the forum.
« Last Edit: December 30, 2015, 06:38:52 AM by Tweakie.CNC »
