Hello Guest it is November 22, 2026, 10:27:10 AM
Author Topic: Mach 4 crashes when canceling Ethernet SmoothStepper plugin config  (Read 8052 times)
32 bit Win 7 Pro, Mach 4.2.0.2803, ESS plug-in 1.0.1.132, ESS at address 10.9.9.9 directly connected to adapter card.
When I Config the ESS plug-in from Mach 4, the dialog opens and if I do nothing except Cancel the dialog, Mach crashes.  I see a dialog with the message "Mach 4 CNC GUI has stopped working".
Thanks for any advice.
Re: Mach 4 crashes when canceling Ethernet SmoothStepper plugin config
« Reply #1 on: December 22, 2015, 08:59:35 AM »
I think this is working now.  I hadn't selected the ESS as the motion device or exited Mach after changing each initial address, etc.  Would be nicer if the notification that a motion controller hasn't been selected were provided by a dialog rather than a crash.
