Hello Guest it is November 21, 2026, 12:49:50 PM
Author Topic: Squaring Gantry with 2 Home Switches  (Read 10408 times)
Offline kolias
  •  1,165 1,165
« on: December 13, 2015, 06:37:58 PM »
One of the many good features of Mach3 is squaring the gantry when you have 2 motors moving the gantry on Y & A with 2 home switches on each axis
Does this feature also works if you only have one motor moving the gantry on Y with 2 home switches on each side?
If it does, how would you configure the Y to be slaved to what?
Nicolas
Re: Squaring Gantry with 2 Home Switches
« Reply #1 on: December 13, 2015, 07:43:32 PM »
How are you slaving 1 motor?
And how does one motor move each side of the gantry separately?
Offline kolias
  •  1,165 1,165
« Reply #2 on: December 13, 2015, 09:32:29 PM »
Sorry Gerry, I knew can not be done but I had to ask in case of altenate way
Nicolas
« Reply #3 on: December 27, 2015, 10:39:16 PM »
May be there are needs in having individual precision clutches in the two axis and actuator controls ....much more cosr!....
