Hello Guest it is November 22, 2026, 11:01:15 AM
Author Topic: help with mach4 parallel port  (Read 23294 times)
« on: December 07, 2015, 02:27:17 PM »
new to MACH.  I have just built a CNC machine and have it all setup on my parallel port and cannot get my machine to move. can anyone help me in trying to figure out why my motors wont move when I jog?
Someone mentioned I need to setup the addressing ???? dont know what that is as of this moment.
Re: help with mach4 parallel port
« Reply #1 on: December 07, 2015, 05:18:55 PM »
I would watch the videos linked in this topic. Should get you going.
http://www.machsupport.com/forum/index.php/topic,27194.msg191918.html#msg191918
« Reply #2 on: December 12, 2015, 10:40:07 PM »
I watched the video's and was able to get my Z axis and Y axis to move but I cannot get the X axis with the dual motors to move. Any idea's ?
Offline dude1
  •  1,253 1,253
« Reply #3 on: December 12, 2015, 10:46:47 PM »
post your .ini it's in you profile in c/mach4
« Reply #4 on: December 12, 2015, 10:56:17 PM »
which file? I dont see a INI file in the root c:\mach4hobby
Offline dude1
  •  1,253 1,253
« Reply #5 on: December 12, 2015, 10:59:15 PM »
C:\Mach4Hobby\Profiles
« Reply #6 on: December 12, 2015, 11:06:55 PM »
see attachment files
« Reply #7 on: December 12, 2015, 11:08:02 PM »
file is now attached to the previous message
« Reply #8 on: December 12, 2015, 11:11:55 PM »
It may be more useful to post a packaged profile which includes not just the
INI file, but also all configuration information about the system.
You can generate a packaged profile by using the menu items-
HELP > SUPPORT > PACKAGE CURRENT PROFILE
This file can then be used by support personnel to run an instance of Mach4 that
uses your complete software setup. To do this, use the Import Profile function
of the Mach4 Loader.
PMDX plug-ins can also create debug logs that are automatically included in
the packaged profile. The PACKAGED PROFILE is just a special ZIP file and the
extra files get included when it is created.
« Last Edit: December 12, 2015, 11:14:43 PM by Steve Stallings »
Steve Stallings
www.PMDX.com
Offline dude1
  •  1,253 1,253
« Reply #9 on: December 12, 2015, 11:13:43 PM »
ok ronnierozier2 can I have that it would be faster than reading the ini file.
thanks steve
