Hello
Guest
it is
September 21, 2026, 05:54:35 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
General CNC Chat
Show"N"Tell ( What you have made with your CNC machine.)
Mach 3 Dual 5c spindle Lathe with Front Mounted 4 way ATC
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Mach 3 Dual 5c spindle Lathe with Front Mounted 4 way ATC (Read 26124 times)
Cncman2nv
90
on:
December 06, 2015, 09:55:34 PM »
Nearing Completion is a dual 5c spindle lathe. The main frame of the lathe was bought a cabin fever '09 from Ajax CNC in Pennsylvania. The rear spindle was created using a Allen Bradley servo motor and a 5C collect closer from grizzly tool you tube channel is cncadam
https://www.youtube.com/watch?v=xyirJ8cPgQo
thanks
Adam
Tweakie.CNC
9,372
Super Kitty
Re: Mach 3 Dual 5c spindle Lathe with Front Mounted 4 way ATC
Reply #1 on:
December 07, 2015, 01:08:59 AM »
Excellent work Adam.
Cncman2nv
90
Reply #2 on:
December 07, 2015, 08:01:18 PM »
Thanks Tweakie... It Has been four years in the making lots of trial and error there is more work to be done but at least I'm at the 90% marker
Adam
chrisjh
132
Reply #3 on:
December 11, 2015, 04:50:17 AM »
Keep up the good work. Very impressive!!
Cncman2nv
90
Reply #4 on:
December 13, 2015, 10:47:35 AM »
Thanks Chrisjh... I couldn't have done it with out your great document on using the G52 Offsets so thank you! and Keep up the good work
Adam
nicad
40
Reply #5 on:
June 14, 2017, 02:55:47 PM »
Nice!! Could you give some insight on how you setup Mach3 to control dual spindles like this? I will be building a lathe very similar to this and need to be able to control dual servo driven spindles (step/dir stream for both spindles).
Thanks!
Print
Pages:
1
Go Up
« previous
next »
