Hello Guest it is October 20, 2026, 02:50:17 PM
Author Topic: How do you reset the text editor and pdf viewers in Mach3?  (Read 9436 times)
« on: November 27, 2015, 01:59:40 PM »
Hello,
I recently reinstalled Mach3 on a new PC. When I did I set the text editor and pdf viewers incorrectly. Now i just get an error message when I try to edit gcode or open the manuals. How can i reset the text editor and pdf viewer to different tools?
Chris
Re: How do you reset the text editor and pdf viewers in Mach3?
« Reply #1 on: November 27, 2015, 02:16:02 PM »
You set the path of the g-code editor in general config.
I don't think that Mach3 has anything to do with a pdf viewer. Isn't it just the default Windows pdf viewer?
« Reply #2 on: November 28, 2015, 07:42:31 PM »
That was it. The pdf viewer is set in Mach Standard Mill. Thanks Ger!
