Hello Guest it is November 01, 2026, 10:12:02 AM
Author Topic: LazyCam 2 Pro Turn Error?  (Read 9565 times)
« on: May 08, 2007, 09:43:23 AM »
I have attached a couple of files. The dxf is from Autocad and the associated turn tap file generated by LazyCam 2.0x.
Mach 3 is hanging when trying to load the tap file.
LC is generating what looks like impossible k numbers in the gcode for Mach3 to process.
Apologies if this is already in hand for fixing or that my dxf is at fault.
Re: LazyCam 2 Pro Turn Error?
« Reply #1 on: May 08, 2007, 11:39:25 AM »
That is a known bug and is fixed for the next rev :) Should be out tonight or tomorrow.
Brian
www.newfangledsolutions.com
www.machsupport.com
