Hello Guest it is September 05, 2026, 11:46:59 PM
Author Topic: Keygrabber problem, (can't find DLL)  (Read 26079 times)
eirwin
« on: May 08, 2007, 09:08:00 AM »
Hello all!
I can't get my Keygrabber to work since I reinstalled Mach 3.  It can't find the DLL.  I tried replacing the shortcut from a shortcut on my other computer, but I am having the same problem.  Does any one know how to fix this sort of thing?
Eliot
Re: Keygrabber problem, (can't find DLL)
« Reply #1 on: May 08, 2007, 10:07:42 AM »
what DLL is it looking for ?
www.newfangledsolutions.com
www.machsupport.com
eirwin
« Reply #2 on: May 08, 2007, 05:45:18 PM »
It looks like a long convoluted string that I don't know that I should try and reproduce here but it ends with "wbem".
There is a lot of repeating of "system 32;WINNT;c;\WINNT", etcetera.  I think that it has the target wrong.
Any idea what I should do to fix it?
« Reply #3 on: May 08, 2007, 06:17:10 PM »
we could get you the DLL but you will need to tell us what it is :)
www.machsupport.com
eirwin
« Reply #4 on: May 09, 2007, 08:33:11 AM »
When I open up Keygrabber, I get a message saying that the DLL is not found and then gives me a long string ending with "wbem".  Isn'tn that the DLL, "wbem"? Do you want me to give you the whole string?  If so, I will go out to the shop and write it down.
« Reply #5 on: May 09, 2007, 08:43:12 AM »
I will need to see the error..  could you do a print screen and save it as a bitmap? Then all you have to do is post it :)
Brian
www.machsupport.com
eirwin
« Reply #6 on: May 09, 2007, 09:05:53 AM »
Ok, I'm sorry.. It is the DINPUT8.DLL that it is looking for.
« Reply #7 on: May 09, 2007, 09:24:50 AM »
I had a look and I have the dinput.dll not the dinput8.dll
www.machsupport.com
« Reply #8 on: May 09, 2007, 09:49:14 AM »
Here you go.
eirwin
« Reply #9 on: May 10, 2007, 12:59:43 PM »
Thanks! :)
I got it working but I have one more question.  I'm using a Microsoft "Sidewinder" Joystick and I have this setup with keygrabber.  It only wants to move one axis at a time. Is there a setting for this?  I noticed that I also have the option of turning it on in Mach. There are different results depending on which xml for Mach that I am running too.
Eliot
