Hello Guest it is November 22, 2026, 10:13:28 AM
Author Topic: using homing switches, as limit switches  (Read 7637 times)
« on: November 18, 2015, 03:37:05 AM »
hi,
I want to use my homing switches, also as limit switches. But I could not do it's adjustment on mach 3 ? my homing switches are working fine, but they only work when I press on mach3 to "reference all home" button. but I want to use them also as limiting. how can I adjust home switches also as limit switches ? thanks.
Re: using homing switches, as limit switches
« Reply #1 on: November 18, 2015, 11:18:02 AM »
You need to enable and set the pin used in limits as well as home.
Don
