Hello Guest it is November 22, 2026, 09:09:15 AM
Author Topic: Spindle Speed never shows RPM, can´t figure why  (Read 10297 times)
« on: November 16, 2015, 03:40:15 PM »
I have set up the Index signal from a parallel port input and it toggles correctly as seen in the Diagnostics window.
But no matter what , RPM values are never displayed in the Spindle Speed window. I even tried emulating with hot-key but although the input shoes the pulses, Mach3 seems to ignore it for reasons I can´t understand.
Hope someone can help me on this, I send attached the xml file.
Thanks.
Re: Spindle Speed never shows RPM, can´t figure why
« Reply #1 on: November 16, 2015, 03:50:26 PM »
Have you enabled the spindle with an M3 command? The speed is only  shown if the spindle has been turned on in Mach3.
Cheers,
Peter
Homann Designs
http://www.homanndesigns.com
« Reply #2 on: November 17, 2015, 07:48:05 AM »
Hello Peter.
Yes, I have also tried the M3 command both in MIDI and g-code file but still the same...
