Hello Guest it is November 08, 2026, 12:30:51 PM
Author Topic: Input problem  (Read 8087 times)
Input problem
« on: November 15, 2015, 11:04:42 AM »
Hi there I have finally got my 626 size mill working after too long, I have good smooth moment but  a problem with any inputs.
 I have Mach 3 and Mach Std Mill so not sure where the problem is. As soon as I only enable a limit switch with no actual connection it lights as though the switch is activated and and has to be switched off at ports and pins before the light goes out.
  I have reinstalled Mach 3 after uninstalling but when I started it again it picked up my licence so was probably not completely stripped out. Quite a while while ago running a simulation  I got the auto  to find an input but since then nothing as when I press the auto find nothing happens.
  Hope you can help me as I've spent far too much effort to fail now. I have the soft limits but would prefer proper home switches ant to use a probe that's  why I  got the MSM.
Regards Bob.
