Hello Guest it is November 13, 2026, 03:14:42 PM
Author Topic: Losing Zero  (Read 44913 times)
Offline russh
  •  40 40
Losing Zero
« on: November 14, 2015, 06:39:40 AM »
Hello All,
Can some one offer some help on an issue I seem to have
Basically, when set my zero positions, I then come to run a program and now and then (more times that not!) it seem to loose its zero positions. I've had a few cases where Z or Y have lost Zero and the tool has crashed in to the work piece.
Initially I though I might be cancelling or calling up an incorrect fixture offset in the G-code with G54, but even when I remove this from the safe line, it still happens
Any help would be greatly appreciated
Rusty
  •  9,377 9,377
Re: Losing Zero
« Reply #1 on: November 14, 2015, 06:54:19 AM »
Hi Rusty,
Sounds like you are loosing steps.
To resolve the problem just one step at a time ( no punn intended)...
Try reducing your Velocity and Acceleration settings ,for each axis, by 50% (in motor tuning) and save the changes -  and then see if the problem persists.
Offline russh
  •  40 40
Re: Losing Zero
« Reply #2 on: November 14, 2015, 07:00:44 AM »
Tweakie,
Huge thanks for the quick reply
Would the "losing sets" issue occur in manual mode as well, I.E If I jog the table around with the MPG wheel, I don't seem to loose zero (well not that I have spotted, but I will recheck this statement as well), it only seems to be during code running
By the way, The problem occurs even if I manually over ride the feed rate right down to a snail pace during program run as well
Rusty
  •  9,377 9,377
Re: Losing Zero
« Reply #3 on: November 14, 2015, 10:27:02 AM »
Hi Rusty,
Reducing the feed-rate is not quite the same thing so try reducing the Velocity and Acceleration by 50% as suggested and report back on what happens regarding loosing position.
Offline russh
  •  40 40
Re: Losing Zero
« Reply #4 on: November 15, 2015, 01:52:11 PM »
Hi Tweakie,
Right, I ran a few tests and record a bit of position information first. I turn the machine on and zero'd the tool to each edge of the vice I had in, then ran a simple movement program with G00 and G01 commands. The machine lost position from the zero points by X: 3-4mm, Y: 3-4mm, and Z: 16mm.
I then changed the Velocity and Acceleration values as you said by 50%.
Original Values
X: Velocity=6000, Acceleration=300
Y: Velocity=6000, Acceleration=300
Z: Velocity=5100, Acceleration=300
New Values
X: Velocity=3000, Acceleration=150
Y: Velocity=3000, Acceleration=150
Z: Velocity=2550, Acceleration=150
I then ran the same simple program (after re-zeroing), and repeated the program a few times. It still lost position, but not as much this time. X: 0.5mm, Y: 0.5mm and Z: 2.4mm
Should I reduce by half again? or do we need to look at something else now?
Offline bfgstew
  •  91 91
  • DOH!!!!!!!
Re: Losing Zero
« Reply #5 on: November 15, 2015, 03:38:21 PM »
Reduce it by half again I would say.
I run mine at 1000 max for velocity, and even that I find is too fast when the machine is cold!
Offline russh
  •  40 40
Re: Losing Zero
« Reply #6 on: November 15, 2015, 04:40:08 PM »
So 6000 velocity was WAAAAAAY to high then!
That was what was in the manufacturers config file!
I will give it a go at half again, and if it still runs out will knock it down a little more
  •  9,377 9,377
Re: Losing Zero
« Reply #7 on: November 16, 2015, 01:13:48 AM »
Hi Rusty,
Wow those Velocity figures you have been using are high.
Perhaps try;  Velocity 2000 and Acceleration 300 and see how that goes.
Offline russh
  •  40 40
Re: Losing Zero
« Reply #8 on: November 17, 2015, 01:11:44 PM »
Right,
I'm now down to 1000 mm/m velocity and just had a more stable run in X and Z, but I still lost about 0.8mm on the Y.
I'm now trying 800 mm/m but is this beginning to look like another issue, or is sub 1000 common?
Offline bfgstew
  •  91 91
  • DOH!!!!!!!
Re: Losing Zero
« Reply #9 on: November 17, 2015, 01:30:00 PM »
How are the motors sounding?  Smooth and humming or jerky and noisy?
