Hello Guest it is September 27, 2026, 08:42:00 PM
Author Topic: M11P1 code to gcode laser  (Read 57015 times)
Offline Snues
  •  16 16
« on: November 11, 2015, 01:34:02 PM »
Hello
Sorry for my bad English.
I build my homemade Cnc Mill with a co2 laser. I'm need some help for a config mach3 M11P1 and M10P2. I read threads Tweakie.CNC and understand. The Problem is the Cad Cam to cut the Drawings.....
With the M11P1 and M10P0? Give a tutorial for Mach3 with pictures step by step ?
A very nice plugin is the Raster for Mach3.
My Hardware
3 x leadshine mf283
1 x Board Lpt to connect pc
Software
Mach3
Autocad
corel draw
Cadcam dxf to gcode
Greetz Bernd
Re: M11P1 code to gcode laser
« Reply #1 on: November 11, 2015, 08:33:41 PM »
M11p1 = output 1 on
M10p1 = output 1 off
M11p2 = output 2 on
M10p2 = output 2 off
(Don't mix up the "p1" or "p2" as it won't work right...)
.... If you are using a motion controller or USB breakout board some of these m codes do not work as it is down to the driver to implement them (not mach3)
... Your post processor needs to be setup to enable and disable the laser using m11 and m10 instead of m03 and m05 which are the other commonly used codes with milling machines
Cadcam dxf to gcode
Rob
Rob
Albert Einstein ― “If you can't explain it to a six year old, you don't understand it yourself.”
Offline Snues
  •  16 16
« Reply #2 on: November 12, 2015, 02:11:55 AM »
Hello
Oh ok i understand p1 and p2 thanks:)
I have a interface card
What is the best Cadcam for laser cuts ?
Bernd
  •  9,374 9,374
« Reply #3 on: November 12, 2015, 02:17:18 AM »
In my opinion Vectric http://www.vectric.com/
« Reply #4 on: November 12, 2015, 02:25:19 AM »
What is sheetcam like?
They sell a laser add-on or module but I'm not sure what it extra...
Rob
Offline dude1
  •  1,253 1,253
« Reply #5 on: November 12, 2015, 03:36:57 AM »
vectric simple as mud
Offline Snues
  •  16 16
« Reply #6 on: November 13, 2015, 02:25:44 PM »
Hello
Thank you. I'll test it. The plugin engraving laser operates m11p1?
Bernd
« Reply #7 on: November 13, 2015, 02:45:11 PM »
No, sheetcam will do. M10/m11 codes without a plugin
I asked what the plugins do and I got this:
http://forum.sheetcam.com/viewtopic.php?t=6777
Rob
Rob
Offline Snues
  •  16 16
« Reply #8 on: November 15, 2015, 05:59:39 AM »
Hello
No I mean the plugin for Mach3
http://www.machsupport.com/software/plugins/
"Imports Photo and outputs DigTrigger at variable number of 5us pulses to trigger laser to grayscale output of image during X motor output."
« Reply #9 on: November 15, 2015, 06:01:47 AM »
Ahh.. Sorry... Don't know anything about that one
Rob
